Vault General Discussion
515 Kudos
Post 1 of 2
2013 Vault browser keeps losing the column headings
184 Views, 1 Replies
05-08-2012 05:28 PM
2012-05-08_1912.pngIn
Vault 2013, I keep having to reset the column headings (Customize View>Reset).  The first time it happened I marked it off as a glitch.  Second time I did a repair install on the 2013 client.  Third time, I ignored it.  This is the fourth time I have done the reset thingy.
 After I reset the browser columns, I customized it a little by adding a couple columns and taking out a few that I dont use.  This time I will export it so I can import it when it happens again.
Whats up with this?
Employee
11 Kudos
Post 2 of 2
Re: 2013 Vault browser keeps losing the column headings
05-10-2012 09:56 PM in reply to: karthur1
Please check if remove current customized configure help -
Close Vault client, go to path "C:\Users\<OS username>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<serverName>\Vaults\<vaultName>\Objects"
delete the xml files. restart Vault client and try again.
Fay Zhang
Software QA Engineer
Data Management
Be sure to check out the Vault Help Wiki!
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
