Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
2013 Vault browser keeps losing the column headings
1 REPLY 1
karthur1
333 Views, 1 Reply
2012-05-08_1912.pngIn
Vault 2013, I keep having to reset the column headings (Customize View>Reset).  The first time it happened I marked it off as a glitch.  Second time I did a repair install on the 2013 client.  Third time, I ignored it.  This is the fourth time I have done the reset thingy.
 After I reset the browser columns, I customized it a little by adding a couple columns and taking out a few that I dont use.  This time I will export it so I can import it when it happens again.
Whats up with this?
1 REPLY 1
yuhui.zhang
in reply to: karthur1
Please check if remove current customized configure help -
Close Vault client, go to path "C:\Users\<OS username>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\Servers\<serverName>\Vaults\<vaultName>\Objects"
delete the xml files. restart Vault client and try again.
Fay Zhang
Software QA Engineer
Data Management
Be sure to check out the Vault Help Wiki!
