In 2013 Inventor, when I change to the Vault browser, and there are some files with the black "X" in a circle, when I hover the mouse of it, it just says "Checked-out". Is that not obvious by the "X"?
If I do the same thing in 2011, It says "Checked Out (by <username>)". Ths is MUCH better.
Looks like we are going the wrong way on this.
Solved by Senthil_Kumar. Go to Solution.
Hi Dan,
I understand your concern . I forwarded this to the development team. Thanks again for reporting this issue.
I brought an inventor drawing file from one project to another and changed the model reference along with an image file. The respective image file is been redirected to the current image which is placed in to the current project folder.
Even then the same old image file is shown in the vault browser and it is not letting me to upload the drawing file saying " the image file is located in an inappropriate location. Either the path should be added or the file should be moved in".
I even tried the "pack n go". I dont wanna add the previous project folder path to the current too. Plz revert back.
