Dear sirs,
I ran the installation successfully for the product suite which we have purchased. However, I created a new vault on the local host and I get the following error when I try to log in. What can I do to correct this?
Kind regards,
Rick
Solved by JamesMcMullen. Go to Solution.
Solved by minkd. Go to Solution.
are you using the correct adms & client because they both need to match each other version wise and product wise?
DarrenP
I assume that installed with the upgrade. Although I installed the 2012 vault server software after I installed the Inventor and the vault. How can I check?
Much Thanks
Rick
The versions reported in the dialog of which you posted the screenshot, are the versions of the server. Afterwards, do a Help >> About ... to see the build version of the client.
It looks like you might be running the "base" Vault client against a Vault Pro Server. If that is the case you need to install the Vault Pro client to use the Vault Pro server.
-Dave
That's it! Okay, So I installed Valult pro and it didn't ask me for licensing info at all. Now when I start it, I am told it cannot obtain a licnense? What did I do wrong?
Rick
you need to have a license file for vault pro
DarrenP
how to obtain a license file call autocad activations 1-800-551-1490
provide serial number, host name, mac adress
you can also read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14379546&linkID=9240617
DarrenP
Okay,
I have Autodesk Design suite ultimate. Not sure how I got the Pro version of the vault server software. I just want to use the basic vault pacakage which comes with the software. I can't seem to find a non pro version of the vault server software. Is this in the installation package for the ultimate download?
Much Thanks
Rick
you have to download from the subscription website: http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=16688578
DarrenP
Dear Sirs,
Thank you for your help so far. It appears I created a situation for myself by inadvertantly installing Valult professional server. I uninstalled it but I can't get past the installation checks becuase it seems to be finding incompatible SQL files remaining from the professional installation. See Vault1.jpg
Condition 2 seems to be appropriate, but when I try to navigate to the folder it suggests I don't find similarly named database files. See Vault2 and Vault 3.
Plus I am on Windows 7 pro and I don't have a documents and setting folder as in the second part of Condition 2.
Condition 3 reccomends that I uninstall an MSSQL$AUTODESKVALT Program, but I have no such progrom in my uninstall list.
Can you please reccomend the files I need to uninstall / backup-rename to allow the installation to proceed?
Kind regards,
Rick
The UAC can be temporarly turned off from inside the Control Panel. In your image #3, the KnowledgeVaultMaster files and the Vault files will have to be backed up (if you are coming from a previous release). After the backup, you can remove those files. Also, if you are coming from a previous release, you will have to backup the filestore which I recall was referenced in image #2. After the filestore and databases have been removed, you should be able to proceed.
-Jim
Thank you Jim,
I am sorry for being such a pain. Okay, in order to remove the files Windows won't let me since the SQL server is running. I can stop it and remove them, but I can't start it again if those files are not there. I cannot run the vault setup without the SQL Server running. How do I get around this?
Kind regards,
Rick
What are the names of the exact files that you are deleting? I just want to double check that it is only the Knowledgevaultmaster and vault. When you remove the files and attempt to start SQL, what error is it throwing? It sounds like you might want to remove SQL and re-install it but am hoping you do not have to go to that extreme.
-Jim
Hello Jim,
Okay, we are making some progress. I cleared that error (you were right I was deleating the wrong file). However, I can't figure out how to get around the last check. Please see Vault1.jpg. It seems to be the same problems I was having with the previous error. Be advised I have no vault data I wish to keep on this PC. I am trying to work local with 2012 for the moment. So whatever is on this PC can be safely wiped out.
Kind regards,
Rick
Honestly, at this point there are two approaches... The easiest approach would be to wipe SQL and start over since the data isn't important. The other approach would be to see if the installer log gives us more details on what is going on with the exception. And once we have the log maybe have a better handle on what exactly is going on to be able to offer a better solution. I personally have never seen the "Exception" error in the pre-check.
-Jim
Hi Jim,
Please let me know if this adds any insight into the problem. I know, I have the UAC on, I just wanted to get to view the log for the exception error.
If I have to wipe out the SQL server is there a white paper to walk me through that?
Kind regards,
Rick
PS Added PDF, much easier to read
I checked with another person and we both agree that you will have to uninstall SQL. You can find the directions on how to remove SQL in the Autodesk Vault Wiki. It is located here: How do I remove the Vault
Let us know if you still have issues.
-Jim
Jim,
You won't believe it, but I got my problems resolved. Thanks for sticking with me and getting me back up and running. I always hear stories about why people dread to install the updates, I guess these things are unavoidable.
Anyway, much thanks!
Kind regards,
Rick
Glad I was able to help. Remember if you need anything to post in the newsgroup, we try our best to help get things resolved.
Jim
