Well, it seems that there were two assembly files--two files out of almost
11,000--that Autoloader's validation process had some kind of problem with.
That was enough to cause the entire two-and-a-half-hour process to fail
without any explanation whatsoever. I opened those two files...nothing
unusual about them, so I poked and prodded them a little, saved them, and
(sigh) ran autoloader again. Half-hour to scan, then another 2.5 hours to
validate and...oh joy; everything's all ducky, and the files pushed up to
the vault.
I'm appalled at the amateurish implementation of this application. Once
again, it creates no log by default unless the entire process completes
successfully--and at that point what would you need the log for? In order
to get it to make a log file that might actually be useful you actually have
to go in and manually add entries to the Windows registry. What kind of
application makes you do that?
Here's a wild thought: We could maybe do this thing--let's call it a dialog
box. Yeah! A dialog box for application preferences. I know it's a little
out of the box, but hang with me here...if you had one of those, you could
put a little check box option thingy in there, to tell the software to write
a log file as it goes, instead of only creating one if it won't be needed
anyway. An Application Preferences dialog box. It's a radical idea, but I
think it's time has come.
Even better, how about the software itself not discarding the last several
hours worth of work for the sake of two bloody files that don't have
anything wrong with them, but somehow can't be validated anyway? How about
some real-world error handling capability? Something a little better than
"hey, I know I couldn't do my job, and I'm not going to tell you why, but at
least I didn't actually crash".
Oh, and go check out the process (it's buried on Autodesk's website) if you
want to call your main vault folder something other than "designs". An XML
file in the vault directory? What kind of funky programming is that? It's
like being back in 1986, trying to get a cheap Sound Blaster knockoff to
work in a DOS/Windows machine.
Autodesk, you're shameless, putting out junk like this.
Walt
