With Vault Pro 2014 something has changed with the commandline workspace sync option and I'm not sure what. I've attached the .bat that we've used for the past couple releases to run the workspace sync from the commandline and now with 2014 it tells me "Error: Not a valid settings file path!"
I'm using the syntax exactly as specified in the wiki. I re-exported my settings again from the Vault Client just in case something changed between 2013 and 2014 and still nothing.
"C:\Autodesk\Vault Professional 2014\Explorer\Connectivity.WorkspaceSync.exe" -N<servername>\PMP -VUmthomas -VP<pwd> -S"C:\Autodesk\settings.xml"
Workspace Sync works great from within the Vault Client
Anyone else experiencing this?
Mike,
What happens when you run it without the options file option? Does it work?
-Hywell
It works, something to do with my settings file but I exported it from the Workspace sync via the Vault Client
Mike
Hi Mike,
Can you import the settings back into Vault Explorer using the Workspace Sync gui successfully?
We may also be able to determine the issue if we can get a copy of your settiings.xml file.
