Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Revision Table taking over.... mild rant alert.
2 REPLIES 2
cbenner
364 Views, 2 Replies
Vault Pro 2013 and Inventor Pro 2013....
Since the day that I chose to enable the Vault Revision Table, every IV drawing that I have checked in, even if I have not used the Vault Revision Table on it... has taken on the characteristics of the Vault Revision table... in other words,.... on checking in drawings that were made and revised prior to this switch, all revisions DISAPPEAR from the drawing!
I understand that with the new revision table, only "released" revisions show up... but why should it wipe clean all of my legacy revision tables, which were created using a revision table style created long before this even existed?  It doesn't even have the same properties!  But it wiped them clean anyway.  One day I'm at revision 3... I check it into the Vault,... BAM... empty revision table.
Not happy about this.
2 REPLIES 2
xavier_dumont1
in reply to: cbenner
200% agree with you. It's not useable for people who works since many years with Inventor and start to use Vault.
Unhappy too...
mbodnar
I am seeing a similar thing here but with new rev tables created/integrated with new drawing templates
In the rev table I have 3 values that the designer fills in and the other 3 that approvers fill in
When we fill in the first 3 values thru Inventor (ie. datacards) all is OK until I push it to the next state (for review) and the JP temporarily wipes the values from the rev table (if I open the drawing, I can see blue cells over the values I typed in)
If the approver then fills the info using Edit properties, and change state to Released, the JP does what it is meant to
I think the rev table integration workflow is flawed and does not allow enough flexibility for the designer to fill in the values when they are completing the drawing.
I dont think many are likely to use it at all the way it currently works
To cbenner
In the revision table there is an option "Update latest revision only", have you tried running with this option to see if it makes any difference? It hasnt in my case. I did have a client describe exactly your issue and we turned the revision table integration off for now
Max Bodnar
