Why would a company choose for Vault Pro above Basic?
That's the choice I am going to face soon.
- We do not need replication to other offices
- We want as much freedom as possible in regards to "Inventoir without Vault"
- main goal is to re use assemblies from older project in new project (which might modified slightly)
- Our company is also looking for an ERP system to use.
- Work @Anonymous = check out a project for a week (or 2) and check back in when in the office.
Solved by ihayesjr. Go to Solution.
Solved by DEDE2232. Go to Solution.
Solved by vladimir_michl. Go to Solution.
For any Vault integration with your ERP, you will need the Pro version.
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
With Vault Workgroup or Vault Professional you have the benefit of using Lifecycle Management that helps you see the state of the design. Vault Basic also does not provide an API. With Vault Workgroup or Vault Professional you will find a ton of useful extensions that will help you to automate your processes, like publishing neutral format documents, like PDF, DXF or STEP. With powerGate from COOLORANGE you even can have an ERP-integration to Vault Workgroup and it can also be embedded into Inventor.
You can review the following AU class.
Vault: What Is It and Why Do I Need It? | Autodesk University
@ihayesjr Great class.
1. Do I understand correctly that the Vault Basic version of "Copy Design" is less then the workgroups/pro version of "copy design"?
2. If you choose to go for Pro, to have all the extra stuff. Can Pro be configured to be as "forgiven" as Vault Basic, with regards to being always as status "Work in progress" on files?
3. Can you just opt to not use lifecycles with Vault Pro Kinda disable Lifecicles?
One thing to know, Vault Professional is Revision based and Vault Basic is Version based. You will see Get and other functions working differently than they did in Vault Basic.
I recommend that you work with a partner to get a good understand of the difference between the two editions before upgrading.
@ihayesjr wrote:One thing to know, Vault Professional is Revision based and Vault Basic is Version based. You will see Get and other functions working differently than they did in Vault Basic.
I think this is very important knowledge to make a correct disciccions. So Autodesk itself don't document this is lecture, classes or anywhere else?
Of course you read a 1000 times the same comparing sheet between Basic, Workspace and Pro, but every time this crucial information is not mentioned. https://www.autodesk.com/compare/compare-features/vault
While I do understand that this information can be hard to find, the Help does section out things that are different between the Vault editions.
Also, there are a lot of AU classes on Vault that detail workflows of Vault Professional.
https://www.autodesk.com/autodesk-university/au-online?query=Vault+Professional
Nothing can replace talking to a partner where they can help you go into the details of your workflows and give you the best possible recommendations to deploy and use the software.
ok, that are hours of video's to watch....
There must be a clear definition of what means working with Basic vs Pro, or what it means to work with versions instead of working with revisions? I guess everyone makes assemblies with parts in them, and then create drawing from it.
Or is it just a simple as saying "It depends on your workflow". I need video's or other sources showing both workflows, inventor cooperating with Vault (not only the Vault only videos) so I can descide if we will be better of going the Vault way (and which one) or leaving things as it is, right?
We have a high-level list here. Compare Vault Products | Vault | Autodesk
We could go into a lot of details about each, which is in the Help but that still will not get you where you want to be.
In the end, it depends on a few things.
You may not get this from reading pages of differences between editions. You can get this by talking to a partner where they can get an understanding of where you are today and where you want to be tomorrow.
Here is an example of the differences in the Get and Checkout workflow in each edition.
Vault 2022 Help | Get or Check Out a File with the Vault Client | Autodesk
