Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro Change category and Change revision Button
5 REPLIES 5
hugo.trepanier
652 Views, 5 Replies
With Vault Pro 2015; what's happening with "Change category" and "Change revision" Button!
I sent a case to the vault support and the answer is: "the only way is on the pull down menu now"!! Why?
Hugo Trepanier
Autodesk MSD Application Specialist
5 REPLIES 5
paul.gunn
in reply to: hugo.trepanier
You can customize the toolbar to include any commands you want. So you are not limited to the out-of-the-box configuration. Here is some information on doing so:
http://help.autodesk.com/view/VAULT/2014/ENU/?guid=GUID-77946A7E-EAAE-4734-9E76-79300AE96887
Paul
mikel_martin
in reply to: paul.gunn
Paul is correct you can customise the toolbar to include the command.
However, there is a slight issue with the workflow. You have to have a file selected in order to see the commands in the custimazation dialog.
Not sure why that is, but we are looking into it.
To answer the question of why; when we looked at the CIP data from customers, we saw that very few people are using the change category, and change revision commands explicitly. Given the data we have concluded that the majority of users (somewhere around 80%) set the category via the rules engine on add, and drive revision through the lifecycle actions.
Because of this we decided that having these commands on the toolbar by default was just adding "noise" to the UI that most users dont care about.
Mikel Martin
User Experience Architect
Autodesk, Inc.
Good, I can see now my commands.
Hugo Trepanier
clastrilla
in reply to: mikel_martin
Thanks Mikel for the info. Can I suggest putting this into the What's New info as well, so we don't think it's an error in the install. Thanks!
in reply to: clastrilla
Ok I can customize my toolbars. But I don't find the command change Category. I have fund change state & revise.
regards,
Dom
