Autodesk Vault Workgroup 2017 and Autodesk Vault Professional 2017 introduce a new security paradigm to provide more control over who can access Vault objects.
Previous Vault releases used role-based security to see if a user had general access to the object type. If the user had the correct role, then Vault used an additional single-gate security system. Administrators could use either object-based security or state-based security. Object-based security was generally derived from folders. State-based security was derived from lifecycle state security rules. This led to problems when an Administrator wanted to use both folder and state-based security.
In addition, users with the correct role would only need to be able to see an object in order to make state changes. Vault was not limiting state changes based on business lines. For example, if a group of engineers in one location could see what another group of engineers was working on, they could make state changes.
More Control Over Security for Specific Business Lines
Vault 2017 introduces a dual-gate security model that combines folder security with state security. Users must now have role permission, and combined folder and state-based permissions to access a Vault object. With this new dual-gate security model, administrators can control individual access to a Vault object based on organizational area or business line.
For example, an administrator can make it so that a group has read, write, and delete permissions but certain members of the group do not have some permissions while in various lifecycle states.
See File, Folder, and Object Security for more information.
Legacy Security Still Available
Customers who prefer the legacy security model or who want to wait before adopting the new dual-gate security model, can still emulate the single-gate security model by selecting Override object-based security in the Definition Security drop-down of the Lifecycle Definition dialog. This option makes it so that every file that is using that lifecycle definition has state security as an override.
Updates to Dialogs and Workflows
In addition, an Effective security label has been added to the bottom of the dialog toindicate the type of security in effect on the selected object.
See Edit a Lifecycle Definition for more information.
Autodesk Vault Workgroup 2017 and Autodesk Vault Professional 2017 introduce a new licensing paradigm.
The single-user subscription license is available with Vault Workgroup and Vault Professional.
The multi-user subscription license is available with Vault Workgroup, Vault Professional, and Vault Office.
Previously, when you copied or published an asset in the Factory Design Suite, you had only two storage options: local or in the cloud. The new Vault integration features let you store, view, and download assets; and manage libraries using Autodesk Vault Professional.
To use this feature, the Vault administrator must first set up your asset library folders. See Configuring Vault for Factory for step by step configuration instructions.
If a user attempts to assign an item to a CAD file without item data, a message displays, informing the user that the action is restricted.
This feature is on by default.
A job described as Extract Item Data <file name> is added to the job queue, where <file name> is the CAD file being processed.
If a file has Item Data (BOM information), the Item Assignable value is True.
In Vault 2015 and Vault 2016, Vault introduced a feature that automatically broke the link between a file and an item during an item update if the equivalences did not match. This proved to be problematic for some users.
Vault 2017 still has this feature but it's now off by default. You can enable this feature by selecting Break file links from items based on Equivalence Value during item update on the Items tab of the Administration dialog.
In previous releases, checking files out from a vault on one machine and checking them in from another was not permitted. As of Vault 2017, users can now check files into a vault from a different machine than the one they originally used to check them out if they are using the Vault Client, the Inventor Vault Add-in, or the AutoCAD Vault add-in.
The Checkout command has been removed from the right-click menu for folders since a quick checkout cannot be performed on folders.
In addition, if there is a local version of the file and it is not the latest version of the file, then Checkout does not check out the file.
Vault Workgroup 2017 and Vault Professional 2017 introduce the ability to multi-select files for File Lifecycle State Change Rollback.
User-defined properties can be created for these links.
In addition, the new linking system allows administrators to import link properties using the Factory.config file so that information about the relationship between two vault objects can be tracked as a property link.
To support this new feature, a new Link association has been created and is visible on the Property Administration interface. Imported Factory property links show this link association as selected.
However, the link properties are not accessible via Custom View in the Vault user Interface (lists and tabs). The Administrator needs to create a custom tab to be able to display link properties.
Vault Workgroup and Vault Professional 2017 introduce a new folder list view in Copy Design. Users can now set a destination path in the folder panel by manually updating the destination folder path or assign the destination folder by using Find and Replace capabilities to update the folder path string.
In addition, users can substitute values, such as the project number, in the folder path by simplifying the new file path in instances where there is a complex rules-based structure, or by individually browsing to folder locations by file.
Vault 2017 improves the security of passwords in the system configuration files to help prevent unauthorized access to other areas of the product.
In addition, administrators can now change the default password for the VaultSys and ADMS_%ADMS_%SiteName% SQL Service accounts from the ADMS Console.
See Change the Password for SQL Service Accounts for more information.
In an effort to reduce installation issues and administrator interactions, Vault 2017 introduces a new Auto-Fix feature for the IIS Connection Timeout and the ASP Status pre-check.
If the system finds an issue with either of these pre-checks during installation, the administrator can click Re-test to have the system attempt to automatically correct the issue.
If you prefer to do this manually, you can leave the install screen to perform the changes, but this simple enhancement for common settings issues can help simplify initial installation.
DarrenP
Solved by DarrenP. Go to Solution.
link is here: http://help.autodesk.com/cloudhelp/2017/ENU/Vault-New/files/GUID-03A0EBD2-F8A2-4191-9EC2-B0108F970E9...
DarrenP
it says that Vault Pro & Workgroup 2017 is being offered as a single user license (standalone) but when you run the installer it only gives you the option for a multi-user license (network)
Edit: Nevermind
Answer is here
A Let's Get Started splash screen appears asking you to select a license type.
For a Single-User Subscription License
For a Multi-User Subscription License
For information on configuring license timeouts and other license attributes, see Configure Your Network License Server.
DarrenP
Thanks for posting that @DarrenP
That is a sorry pathetic list of new features, reflected by how empty and dead the beta program was this year. The Vault team have implemented a mere 5 out of the top 50 most upvoted requests on the IdeaStation. Look below, the purple lines are what are implemented now, one was just an added prompt and they're mostly requests which spawn from 2012.
That What's New list is a bunch of things you'd expect to gloss over and be secondary to big new enhancements. There is nothing in this release which will make me feel less suicidal when having to manage it on a daily basis.
i guess the only good thing the system requirements didn't change from 2016
DarrenP
don't know if you have been keeping up with this product but A360 is starting to turn into Vault more & more
https://blog.a360.autodesk.com/keep-track-of-the-design-process/
DarrenP
Hmm. I'd love to be a fly on the wall when someone tries to check in a 1GB assembly to a cloud based A360 "Vault" through a 2mbps up line.
Why should I put my designs on Autodesk's servers?
Steve Walton
@DarrenP, I'm curious to know more about the licensing model. "Single-User" How does that work? Are Vault licensing now being requested by the client or is it still the server?
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
The Single User license is currently a lie. Autodesk Licensing has stated to me in three seperate support cases that Single User is still being worked on even though it is listed as a new feature. I haven't been able to find any Material numbers for it yet either.
What I did find interesting though...you can now borrow a license from the server like you can with Inventor. Its under the Manage License option for the A360 sign in.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
thats what i don't know
the client still pings the adms console for a license still
DarrenP
You indicated "you can now borrow a license from the server like you can with Inventor. Its under the Manage License option for the A360 sign in".. What's the purpose of this? If you can't access Vault remotely what's the sense of borrowing a license...
Mark Lancaster
& Autodesk Services MarketPlace Provider
@scott_baker can you comment on the Vault licensing model?
Darin Green
Scenario...
Company has 50 seats of Vault Pro...
Company has 80 users...
Engineers 1-10 don't want to risk not getting a license when they refresh or launch Vault Pro...they have it and it doesn't get returned to the pool after 30 minutes of inactivity.
Ok, Maybe..
But borrowing is technically used for when you go off the grid and have no access to the license server. If someone wants to control license for Vault, I would be using the option file method that started with Vault 2016. So I don't buy that as a reason, sorry...
I'm just having fun here because we have a list of new Vault features but some are not included..
Mark Lancaster
Well not every IT is saavy enough to set up an easy options file, but I'll give you another reason and its completely selfish... 🙂
We store our Vault Pro licenses on a shared server that we can only access when on our domain. I however have a local Vault and I am almost never on the domain if I don't have to be, so in the past I setup a local NLM and got a license with only 2 or 3 licenses on it, now I don't technically have to do that (I still did though). Just another bit of flexibility. So while this would be in the 1% group, you could have a reason that your NLM and your Vault are not on the same domain. Maybe you are doing contract work and you have your own Vault setup, but you are using licensing from the client.
i'm still not seeing a use of the borrow license for vault because if you borrow a license and you go offline then you go to a client site and log in to their vault wouldn't you just grab a license from their pool since you are logging onto another ADMS console?
DarrenP
Thanks for the info Darren. Do you know if useres with Vault Workgroup 2017 have Thin Client access?
no this is a Vault Pro feature
DarrenP
