Hi Everyone,
I have an urgent question to ask.
We are upgrading our vault from 2011 to 2012 and moving it to a new server machine.
The scenario is
Current server (In service): (32 bit)
Running Windows server 2003 Std edition (SP2)
Sql server 2005 workgroup ( Database Size is 9.1 GB)
Autodesk Data management Server Console 2011
New Server Planned: (64 bit)
Windows server 2008R2 Std Edition
SQL Sever 2008R2 WORKGROUP (No Service Pack)
vault Server 2012
Question # 1:
In the System Requirements for Vault 2012, following is mentioned as approved Sql Sever software
Microsoft SQL Server 2008 Express, Workgroup, or Enterprise edition (SP2)
or Microsoft SQL Server 2008 R2 Express, Standard, or Enterprise edition
This does not list Microsoft SQL Server 2008 R2 "WORKGROUP" edition. Is that an error in documentation or did I order wrong software. our current database size is 9.1 GB.
Question #2:
What would be the process of migration? As I understand it---
1. Create a backup of the Current Database using ADMS Console 2011
2. Create a list of current users and their roles.
3. Copy the Database to new server in the same folder location as in previous machine.
4. Install Vault 2012 on new machine.which will recognise the database.
5. Migrate the database to 2012 edition.
6. Add Users as they were in previous setup.
Any Help is appreciated.
Regards
Lalit
Solved by ihayesjr. Go to Solution.
Q1 - The documentation is correct. We do not support SQL Server 2008 R2 Workgroup edition.
Q2 -
We are a small company with 3 seats and abour 9.1 GB of datdabase. It seems that the only way forward is to go for a costly option of SQL2008R2 standard .
Is there any other option?
You can move to SQL 2008 Workgroup.
