I renamed a file in my vault and now when I try to check out the file I get a error saying my filename or path is too long (More than 260 characters.) But when I counted the number of characters in my file it was less than 150. Any ideas what is going on. Thanks in advance.
Solved by Richard.Rankin. Go to Solution.
You need to be sure to count all the characters in the path as well. If this is happening on check out you should count the characters in the path to the working folder, plus all folders up to the file and the file name itself. So if your working folder is C:\user\My Documents\Vault and the file is the in $\Folder1\Folder2\Folder3 folder in Vault you'd have to count "C:\user\My Documents\Vault\Folder1\Folder2\Folder3\filename.ipt" as the total length.
This is also important to consider when deciding where your filestore will reside as well.
That is what I did. The file path is as follows C:\Documents and Settings\Kyle\My Documents\Vault\Designs\Products\REMAP\REMAP 1kN\3D Model\Workspaces\Workspace\Torque Cell2.ipt
Which is 129 characters. So I still do not understand where the other 131 characters are coming from.
Turns out it might actually be your Temp location and not your working folder ...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13288133&linkID=9261340
Do you have any simulation files in a referenced assembly? I believe filenames in referenced assemblies will also show as being to long. Below is an example of the automatic simulation file naming (this is the path BELOW the assembly file):
\1001-ME-A0127\AIP\Stress Analysis\{E5169E6C-DA05-440B-8A3F-CE68F0135B2D}\Brep_0\1001-ME-A0127_INS_{28AC9A0A-14B0-45B5-A815-0B1BF97DCEBE}.fins
Yes I do have simulation files for the part that says the file/path length is too long. If I go into the folders for the simulation files in the vault explorer it displays the same message about max file/path length before I even try to open them. I just realized that these files path length are over 260 characters. Could this be causing the part to not open. And if so can I just delete them to make my file part work again.
Scott,
I noticed that the TS document mentions that this is a limit imposed by Windows. I have been using Windows 7 with Vault 2010. I have now upgraded to Vault 2011. The very first time that I tried to rename with Vault, I get this error message.
I NEVER saw this message with Vault 2010.
Some of the files that are included in the assembly (but I did not rename these) are frame generator files. These are the ones that would have the longest path names. I count this path+filename to be 101 characters. Not sure where the other 145 are coming from.
The "Temp" folder in Windows 7 is C:\Users\<User Name>\AppData\Local\Temp, which adds only 27 not counting the username.
Could there be something else causing this error message?
You can try Long Path Tool. It deletes/unlocks, copies/renames path too long files/folders.
It is the best tool to end your problems in unlocking, managing and renaming files that appear to have a long filename.
Since in some instances, you may have experienced problems accessing, managing and even renaming files that have more than 255 characters, this utility has been made to answer this particular scenario. If you have also encountered problems like error messages that tell you that the path too long, too long path, destination path too long or cannot delete file then this program is definitely for you.
This will totally take place of Windows Explorer, Far Manager or other file managing utilities since this is maybe used in any type of Operating System even the earliest Windows 95 version.
You can get it from [url=http://longpathtool.com/]Long Path Tool[/url]
Long Path Tool helped me in this situation
Long Path Tool help me a lot when i have an issue like file deleting or renaming the file. Also good to use if file name and file extension is too long.
Also, with your simulation files, turn off the OLE links so you don't get those darn long sim file names anymore. Very annoying they are turned on by default.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Long too path error!
"Long path tool" is very helpful for this problem. You can solve this problem like copy, delete, long path files by using this tool.
I used to have similar problems too, but after using "long path tool" everything was solved.
Long path tool is the very good program for error, unlock solution. Try it and solve your problem. I used long path tool and I solve my error, unlock problem solution. |
