Solved by Richard.Rankin. Go to Solution.
Another example. Copy Design throwing the exact same error.
Vault Basic 2014 wih SP1 on Win7 x64 clients. Affects all standard users on all PCs.
I'm not certain when it started, but pretty sure it's since we moved to 2014 3 weeks ago. Certainly worked OK with Vault 2013 on Win7.
Have tried:
Replacing the IPJ (there's only one, and it's in the root folder).
Migrating files to Inventor 2014 (it happens with brand new files too)
Rebooting Server & Clients.
Installing Inventor SP1 (and rebooting again)
Turning off UAC is not an option for us unfortunately but I did test it logged in as a Domain Administrator and it worked perfectly so it looks like it's a similar issue. I can see the files being copied down to the C:\TEMP folder, then the error dialog appears. Clicking OK on the dialog cancels the operation and the files are removed from C:\TEMP.
Will log a call with Autodesk but wanted to post this anyway, just for the record!
#EDIT# By the way, Rename seesm to work fine, it's only Copy Design that's broken.
Donnie.
P.S. Hi Mr Cross! How's life in the sun?
One of our clients reported the issue on file renaming (even so she renames IPT the error is about renaming DWF).
I as administrator don't suffer any problems with the same renaming.
Vault Server version: Pro 2014 SP1 update 1 (build 18.1.8.0)
Client
OS: Win7 64bit Russian
Vault Explorer version: Pro 2013 SP1 Russian
Just in case - VE2010 is also installed on the PC
FYI, In our case insatalling Vault Explorer 2014 SP1 update 1 have helped
I had the same problem. I was able to correct the error by making sure Inventor was open and registered before trying to copy design
Vault Pro 2014
Inventor Pro 2014
Hi -
we just encountered this error during a copy design in Vault Professional 2015.
We figured out, that the project file (ipj) contained a library path within the project path itself. Vault did not like this cascading combination.
This combination was not a problem in 2013 (we updated from 2013 to 2015).
Good luck
Donald! Sorry just came across this, currently waiting on Symetri to give me some stuff so I'm trawling the forums throwing in my two pence!
Life in the sun? Well, I'm in Newcastle so it's ruddy baltic. You're further away from the equator so one won't complain too much. But asides from that it's all good!
Is there anything left to contribute to this issue? Don't particularly want to trawl through 5 full pages but the last few posts appear to be folk confirming a fix.
Just encountered same issue on one of my own VM Servers, Vault Professional 2015 SP1, Disabled UAC on Vault server. Problem is still there,
deleted Inventor Project file from Vault, Created new vault project file in inventor, checked it back into vault
All working fine
Ian
Vault Managed Services
This issue keeps popping up… In Inventor 2015 the problem occurred because the Inventor/Vault project file did not have any mapping to the Project Root and Libraries. Mapping the folder fixed the problem in my case.
Hi Everyone,
Although a very old thread, this continues to be one of the most read Vault forum threads ever.
Autodesk Support have handled a number of these issues over the years and have consolidated various solutions into one troubleshooting article.
Troubleshooting "Unspecified error" (Exception from HRESULT: 0x80004005(E_FAIL))
To hopefully help future readers, I will mark this posting as the accepted solution so that you can jump straight to it, without having to read the whole thread.
