I'm using a VDF grid to display some files. It works well, but sometimes, I've got this message:
Votre compte est déconnecté d'Autodesk Data Managment Server. Vous devez vous connecter pour accéder au coffre-fort
In english:
Your account is disconnected from ADMS. You must log in to access the vault.
It only happens when the VDF grid is visible (the grid is on a custom tab).
Solved by FRFR1426. Go to Solution.
The exact error in english is:
Your account is logged out of the Autodesk data managment server. You must log in to access the vault.
Just found what was going wrong. In fact, each time a new user logs in, you have to recreate the column configuration because the associated connection becomes obsolete and the retrieving of the properties fails.
