Vault Customization
Vault Customization
mikazakov
Message 1 of 4 (178 Views)
VaultFileBrowser problem with download file
178 Views, 3 Replies
11-29-2012 10:59 PM
I can't understand why sample no work.
FilePath non empty.
See attach.
I have Vault 2012
Employee
Redmond.D
Message 2 of 4 (156 Views)
Re: VaultFileBrowser problem with download file
12-04-2012 11:20 AM in reply to: mikazakov
You say that filePath is not null.  What about vaultExplorer and file.  Are those null?
If that is not the problem, I suggest catching the exception.  That way you can call ToString on the Exception and write the result to a text file.  Post the file contents to the discussion group, and I will take a look.
Doug Redmond
Software Engineer
Autodesk, Inc.
http://justonesandzeros.typepad.com/
Valued Contributor
mario.lung
Message 3 of 4 (131 Views)
Betreff: VaultFileBrowser problem with download file
12-13-2012 07:59 AM in reply to: mikazakov
I have the same Problem with Vault 2012 Pro Update 1 and Update 2 installed
LoadExplorer is always Empty
-> my app is a Inventor AddIn the Login in to Vault so File Search works fine
    the .File get all Information and works great
    but the Download dosent work see attachment to see how i want fill the VaultExplorer
thx for help
Guru
Employee
Redmond.D
Message 4 of 4 (119 Views)
12-14-2012 04:18 AM in reply to: mario.lung
So LoadExplorer returns null, but no exception is thrown....
Here is something to try:
Use the overloaded version of LoadExplorer, which requires you to pass in the path to the Vault client EXE.  What happens when LoadExplorer is called?
Doug Redmond
Software Engineer
Autodesk, Inc.
Announcements
Need installation help?
