I can't understand why sample no work.
FilePath non empty.
See attach.
I have Vault 2012
You say that filePath is not null. What about vaultExplorer and file. Are those null?
If that is not the problem, I suggest catching the exception. That way you can call ToString on the Exception and write the result to a text file. Post the file contents to the discussion group, and I will take a look.
I have the same Problem with Vault 2012 Pro Update 1 and Update 2 installed
LoadExplorer is always Empty
-> my app is a Inventor AddIn the Login in to Vault so File Search works fine
the .File get all Information and works great
but the Download dosent work see attachment to see how i want fill the VaultExplorer
thx for help
Guru
So LoadExplorer returns null, but no exception is thrown....
Here is something to try:
Use the overloaded version of LoadExplorer, which requires you to pass in the path to the Vault client EXE. What happens when LoadExplorer is called?
