Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
VaultFileBrowser problem with download file
3 REPLIES 3
mikazakov
401 Views, 3 Replies
I can't understand why sample no work.
FilePath non empty.
See attach.
I have Vault 2012
3 REPLIES 3
Redmond.D
in reply to: mikazakov
You say that filePath is not null.  What about vaultExplorer and file.  Are those null?
If that is not the problem, I suggest catching the exception.  That way you can call ToString on the Exception and write the result to a text file.  Post the file contents to the discussion group, and I will take a look.
Doug Redmond
Software Engineer
mario.lung
I have the same Problem with Vault 2012 Pro Update 1 and Update 2 installed
LoadExplorer is always Empty
-> my app is a Inventor AddIn the Login in to Vault so File Search works fine
    the .File get all Information and works great
    but the Download dosent work see attachment to see how i want fill the VaultExplorer
thx for help
Guru
Redmond.D
in reply to: mario.lung
So LoadExplorer returns null, but no exception is thrown....
Here is something to try:
Use the overloaded version of LoadExplorer, which requires you to pass in the path to the Vault client EXE.  What happens when LoadExplorer is called?
Doug Redmond
Software Engineer
