I am doing some testing with the Vault 2014 API samples. I get an error when I'm trying to run the VaultBrowserSample. I get the following error message. Could somebody help me figure out what I'm doing wrong?
Solved by lornemartin. Go to Solution.
That exception indicates that the Library class static constructor failed. Can you inpsect that exception and look ath the InnerException property and tell us what that is? That might give us a clue as to what is going wrong.
- Matt
