In my custom application to "Vault Browsing" (derived from the example provided with the SDK for the Vault 2015), if I perform the login "read only" in this way:
Vault.Results.LogInResult results = Vault.Library.ConnectionManager.LogIn(
"MYSERVER", "MYVAULT", "myuser", "mypwd", Vault.Currency.Connections.AuthenticationFlags.ReadOnly, null);
instead of:
Vault.Forms.Library.Login(null);
everything is ok but
the VaultBrowserControl does not display the image of the icon of the property "EntityIcon" (and also the Vault Status icon).
Inside the column appears only the property description.
Where I'm wrong?
Thank you.
This blog post gives a workaround to this issue:
