I am new to Vault and Vault Customization,
This is Vault 2015 ADMS and 2015 client.
Here is what I am trying to do and may be i didnt understand.
I was working on this http://justonesandzeros.typepad.com/blog/2012/06/vault-on-android-poc-app.html
to build a small poc to check the capabilities.
I am getting following error.
expected END_TAG
Here is the code updated,
From: WSDL_TARGET_NAMESPACE = "http://AutodeskDM/Services/Security/11/15/2011/";
To: WsdlTargetNamespace = "http://AutodeskDM/Services/Security/1/22/2014/";
String soapAction = "http://AutodeskDM/Services/Security/1/22/2014/SignIn"; (Not sure if signin is correct)
When I try the followin in the browser:
http://127.0.0.1/AutodeskDM/Services/v19/SecurityService.svc
I get the following in the web browser
SecurityService Service You have created a service. To test this service, you will need to create a client and use it to call the service. You can do this using the svcutil.exe tool from the command line with the following syntax: svcutil.exe http://127.0.0.1/AutodeskDM/Services/v19/SecurityService.svc?wsdl You can also access the service description as a single file: http://127.0.0.1/AutodeskDM/Services/v19/SecurityService.svc?singleWsdl This will generate a configuration file and a code file that contains the client class. Add the two files to your client application and use the generated client class to call the Service. For example:
When I go in to http://127.0.0.1/AutodeskDM/Services/v19/SecurityService.svc?wsdl
I couldnt see http://AutodeskDM/Services/Security/1/22/2014/SignIn
My Questions:
