My Vault tab is missing from my ribbon in AutoCAD so items that I have checked out from Vault cannot be checked in from AutoCAD back to Vault.
If I right-click on the ribbon and go to 'Show Tabs' Vault is not in that drop down menu.
Any suggestions?
Probably the Vault. Try:
1. Go to Control Panel->Add Remove Programs
2. Select Vault Client - Add/Remove Features and then check whether AutoCAD Mechanical Add-in was selected or not. If not select and install
Kudo's Senthil from Autodesk...
