Hi to all, is it possible to customize the Vault Toolbar by adding custom fonction (VB.NET)?
If yes, is there any instructions somewhere to do this?
Thank's!
Alain
Solved by Daniel.Du. Go to Solution.
Are you trying to customize toolbar of CAD products or Vault Explorer? If it is toolbar of CAD system, then you can refer to the CAD product API, for example AutoCAD API to create a ribbon botton, and then calling Vault WebService API to communiated with Vault.
If you are trying to customize Vault Explorer, please refer to the document and sample in Vault SDK, it is in C:\Program Files (x86)\Autodesk\Autodesk Vault 2015 SDK\ if you install it on x64 machine.
