After i checked out this assembly and created a new drawing, the VDS dialog box displayed with only the cancel button available even though the data was filled in.
I had to select cancel for at least 50 times, then i could not check the file in because it needed to be saved.
When i tried save again, i had to select cancel 50 times again.
the only way to get it checked in was to disable the datastandard and then save and check in.
we tried to reproduce this on our end, but no luck. can you reproduce it? with different files? We may use a different workflow, so could you please make a short video so that we can mimic the exact same steps?
thanks!
ciao
marco
