I would like synchronize Standard DWG Properties.
my AutoCAD is set like :
... <PropertyDefinitions> <PropertyDefinition PropertyName="Comments" DataType="Text" SyncDWGProperty="true"></PropertyDefinition> <PropertyDefinition PropertyName="Subject" DataType="Text" SyncDWGProperty="true"></PropertyDefinition> <PropertyDefinition PropertyName="Author" DataType="Text" SyncDWGProperty="true"></PropertyDefinition> <PropertyDefinition PropertyName="Keywords" DataType="Text" SyncDWGProperty="true"></PropertyDefinition> <PropertyDefinition PropertyName="Title" DataType="Text" SyncDWGProperty="true"></PropertyDefinition> </PropertyDefinitions> ...
my Autocad.xaml is also set like:
... <TextBox Grid.Row="2" Text="{Binding Prop[Subject].Value}" ... <TextBox Grid.Row="4" Text="{Binding Prop[Author].Value}" ... <TextBox Grid.Row="6" Text="{Binding Prop[Keywords].Value}" ... <TextBox Grid.Row="8" Text="{Binding Prop[Comments].Value}" ... <TextBox Grid.Row="10" Text="{Binding Prop[Title].Value}" ... ...
But only Comments's property and Author's property are syncronize between Data Standard and AutoCAD !
Are there someone who has had this problem and how to solve it?
Best regards,
Solved by marco.mirandola. Go to Solution.
Solved by Stemdriller. Go to Solution.
I feel your pain
I am also having issues and had the same problem as you. I had to recreate the DWT, which fixed the problem for me. But now it will not read the {Workspace} in always tries to save files in C:\Users\........ even though it was working ok??
I feel this Data Standards is very flaky and not stable.
Very worrying
Gareth
Gareth,
hi there, i just tried on my machine and it worked (english AutoCAD). Here a short video of what i did: https://www.dropbox.com/s/v24gnur21tvr54c/DS%20AutoCAD%20prop%20mapping.mp4?dl=0
could you confirm that you do the same? which language of AutoCAD do you use?
can you share you cfg and XAML file?
ciao
marco
Gareth,
Using AcadISO.dwt template that works.
So I renew mine and it works also.
Thank you
