HI all
trying to work out the best way to checkin all parts and drawings associated with a selected assembly file.
The checkout using the InteractiveAcquireFIleSettings method is great but it would be nice if there was a similar method for checking in files.
Any suggestions would be appreciated
thaks Wayne
Hi Wayne,
I am looking for the same possibility. Does anyone find a solution?
Georg
I did not find similar functions in vault 2014 API to do it with one step. You may have to find the associations with DocumentService and checkin them seperately.
Disappointed 😞
do you know if it is possible to call the internal inventor vault checkin command from a vb project. I have seen some discussions on calling inventor commands programmatically when the API does not provide a method. The only issue is when the command requires additional parameters i.e. from a dialogue box.
Yes you can using the
thisapplication.commandmanager.controldefinitions.item("LoginCmdIntName").Execute() or "LogoutCmdIntName" to logout.
You can then use the "VaultCheckInTop" command to check in the drawing and associated parts/assemblies.
Was wondering if there is an equivalent command that doesn't display the login or logout dialogue box
