Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Using iProperties in Define Custom Numbering Schemes
1 REPLY 1
cnguyen
238 Views, 1 Reply
We start usingDefine Custom Numbering Schemesin Vault professional 2012 for our filename. Could anyone please tell me how can we use any of iProperties in Define Custom Numbering Schemes? For example, we want to use "stock number" property in our frame generator member filename (ie. W 10x40-00001). Is there a way to set it up? Thank you
1 REPLY 1
Daniel.Dulzo
in reply to: cnguyen
You might also want to post this question on the Autodesk Vault discussion group because your question seems to focus on configuring an existing feature in Vault while the Vault Customization discussion board is primarily about adding or creating novel functionality in Vault with custom extensions or applications using the Vault SDK.
Daniel Dulzo
Software Engineer
