I'm trying to use the new 'BOM component related properties on the ItemAssoc proxy' feature in 2015 R2. To read those properties I think I have to use these functions:
- WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId
- WebServiceManager.PropertyService.GetProperties
If that's true I need to know the EntityClassId for the ItemAssoc class. Can anybody help me?
Solved by KarlR.J.Wehr. Go to Solution.
I just found out, that you have to approach the problem in another way 😉
- WebServiceManager.PropertyService.GetAllAssociationPropertyDefinitionInfos gives you all the PropertyDefs
and
- WebServiceManager.ItemService.GetItemBOMAssociationProperties gives you the Property objects with the desired values...
