Vault Customization
amitk_189
Message 1 of 19 (620 Views)
Update Attachment
620 Views, 18 Replies
01-29-2013 12:45 AM
I am using Vault Professional 2013 and customzing using C#. I am stuck up with updating issue.
Problem: My current problem is to update only attachment file, not the original file.
Lets consider we have dwg file and its assiciated dwf. I download this dwf make certain changes and upload to vault.
How to update only attachment file.
Regards
Amit
Employee
Redmond.D
Message 2 of 19 (608 Views)
Re: Update Attachment
01-30-2013 05:15 AM in reply to: amitk_189
You check out the attachment, make your updates on disk, and check in the attachment.
Doug Redmond
Software Engineer
http://justonesandzeros.typepad.com/
amitk_189
Message 3 of 19 (603 Views)
01-30-2013 08:37 PM in reply to: amitk_189
Thanks for reply Doug, I actually did this but the associativity between dwg and dwf is lost.
When i click in dwg it won't display this preview. Can you suggest me some methods on how to do this.
Rgds
Amit
Employee
Redmond.D
Message 4 of 19 (587 Views)
01-31-2013 04:38 AM in reply to: amitk_189
What does your check-in code look like?  Are you keeping the same classification and hidden values?
Doug Redmond
Software Engineer
amitk_189
Message 5 of 19 (582 Views)
01-31-2013 09:57 AM in reply to: amitk_189
This is my code for checkin
I refered from this below link and made some modification to suit my requirement
http://adndevblog.typepad.com/manufacturing/2012/06/using-vault-apis-to-check-inout-files-from-an-in...
// Check in the file
public Autodesk.Connectivity.WebServices.File Checkin(Autodesk.Connectivity.WebServices.File file, FileClassification fileClassification, Boolean hidden)
Autodesk.Connectivity.WebServices.File retFile = null;
string filePath = Path.Combine(kCheckOutPath, file.Name);
using (FileStream stream = new FileStream(filePath, FileMode.Open,FileAccess.Read))
byte[] fileData = new byte[stream.Length];
stream.Read(fileData, 0, fileData.Length);
ByteArray IFileData=new ByteArray();
IFileData.Bytes=new byte[stream.Length];
stream.Read(IFileData.Bytes, 0, IFileData.Bytes.Length);
// Perform the upload
if (fileClassification == FileClassification.DesignVisualization)
retFile = mgr.DocumentService.CheckinFile(file.MasterId, "",false, System.IO.File.GetLastWriteTime(filePath),null , null, false,file.Name, file.FileClass, hidden, IFileData);
for (int i = 0; i < fileAssocParamList.Count; i++)
FileAssocParam param1 = (FileAssocParam)fileAssocParamList[i];
if (param1.CldFileId == file.Id)
param1.CldFileId = retFile.Id;
System.IO.FileAttributes attr = System.IO.File.GetAttributes(filePath);
//the local file can't be read only.
if ((attr & System.IO.FileAttributes.ReadOnly) == 0)
System.IO.File.SetAttributes(filePath, FileAttributes.ReadOnly);
else
// Get bom
Autodesk.Connectivity.WebServices.BOM tbom =mgr.DocumentService.GetBOMByFileId(file.Id);
FileAssocParam[] paramArray = (FileAssocParam[])fileAssocParamList.ToArray(typeof(FileAssocParam));
//retFile = mgr.DocumentService.CheckinFile(file.MasterId, file.Comm,false, System.IO.File.GetLastWriteTime(filePath),paramArray, tbom, true,file.Name, file.FileClass, hidden, IFileData);
retFile = mgr.DocumentService.CheckinFile(file.MasterId, file.Comm, false, System.IO.File.GetLastWriteTime(filePath), paramArray, tbom, true, file.Name, file.FileClass, hidden, IFileData);
if (System.IO.File.Exists(filePath) == true)
return retFile;
Thanks and Regards
Amit
Employee
Redmond.D
Message 6 of 19 (577 Views)
01-31-2013 12:40 PM in reply to: amitk_189
That code looks correct to me.  The next thing to try is AddDesignVisualizationFileAttachment.  Use that function to create a new link from the parent DWG to your new DWF version.
Doug Redmond
Software Engineer
amitk_189
Message 7 of 19 (572 Views)
01-31-2013 08:56 PM in reply to: amitk_189
Ok Doug, thanks for information. I will work on it and get back to you.
Rgds
Amit
amitk_189
Message 8 of 19 (564 Views)
02-01-2013 02:21 AM in reply to: Redmond.D
No Doug, i am not able to use AddDesignVisualizationFileAttachment. I am still under confusion on how to achieve this.
Employee
Redmond.D
Message 9 of 19 (558 Views)
02-01-2013 04:20 AM in reply to: amitk_189
You need to be more specific.  Are you getting an error when using AddDesignVisualizationFileAttachment?  Are you confused on what to pass in?
Doug Redmond
Software Engineer
amitk_189
Message 10 of 19 (554 Views)
02-01-2013 07:45 AM in reply to: amitk_189
Yes Doug, you are absolutely right I am getting confused on what to pass.
I tried to get AddDesignVisualizationFileAttachment in place of FileDesignVisualization, but the object doesn't exists. What exactly should i pass to methods.
Rgds
Amit
