Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
The splash screen is stretched if the default system fonts is changed
1 REPLY 1
smilinger
449 Views, 1 Reply
I tried to change my default system font recently, and then i found that the splash screen of Vault is stretched, see the pictures below.
I think the developing guy has set the AutoScaleMode property of the splash screen to "Font". Sure it is not big problem, just a little weird. And it does not behave this in the other applications from Autodesk.
I am using Windows 7, I changed my default system font as follows, the font used here is "Microsoft Yahei":
Splash screen with default system font:
Splash screen after changing the default system font:
Tags (1)
1 REPLY 1
wayne.brill
in reply to: smilinger
This appears to be a product support type question and is not related to the Vault API. Also there is not a Vault API call that would change this behavior.
If you have not done so please post the question to the Vault discussion group:
http://forums.autodesk.com/t5/Autodesk-Vault/bd-p/101
Wayne Brill
Developer Technical Services
Autodesk Developer Network
