Inventor drawings (idw or dwg) can have more than one sheet. Is it possible to read how many sheets an Inventor drawing lying in Vault has with the Vault API?
Solved by Vladimir.Ananyev. Go to Solution.
I think you have to use Inventor API for this purpose.
DrawingDocument.Sheets.Count property returns the number of Sheets in this document.
You may access the document in the invisible mode to speed up the process.
ApprenticeServerDrawingDocument.Sheets.Count is another and even faster option.
OK I see. I’ll continue to use Inventor API. I just wondered if where a method in Vault API that I hadn’t found. Thanks for your answer.
