Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Server Side Customization
6 REPLIES 6
amitnkukanur
565 Views, 6 Replies
Untill Now I was doing custoomization in client side, is it possible to do customization on server side for web services.
rgds
Amit
Senior Software Engineer
6 REPLIES 6
minkd
in reply to: amitnkukanur
If by customization you mean "executing custom code", then no.
However, the server provides a great deal of customization via configuration: user-defined properties, categories, lifecycles, revision schemes, etc.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
Hello Minkd,
Thanks for replying.
My Point of view here is doing customization on server side which will affect all clients connected to it.
For instance i will deploy a web services app on server side and it should be circulated to all clients connected to it.
rgds
Amit
minkd
I'm not sure if I understand ...
Are you trying to write the equivalent of the "Vault Office" web client?
Are you are looking for a way to use the Vault Server to distribute your add-in?
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
Hello MinkD,
Thanks for reply.
I am looking for the second option which you mentioned. Is it possible to customize in Vault Server so that addin will circulate to all clients connected to it.
Else in usual case what happen is if we develop addin, we need to install in all vault clients, rather than going for a distributed application in server.
Cheers,
Amit
minkd
The Vault server does not provide any add-in distribution capability.  All Autodesk supported Vault clients are installed and updated independantly of the Vault server.
You may want to look into "Project Thunderdome", which apparently supports some notion of deployments from the server. However, I am not personally familiar with this tool.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
Hi MinkD,
Thanks for replying and thanks for providing the insights for customization on server side.
rgds
Amit
