Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
SelectEntitySettings limit to a folder and its sub folder
2 REPLIES 2
wesbird
306 Views, 2 Replies
  I start to use SelectEntity and SelectEntitySettings to select File.  I want limit my end user only select File under folder $/A and its sub folder, for example. I know I can use InitialBrowseLocation to set inital folder. if I set RestrictNavigation = true, then only File under $/A can be selected, not the sub folder like $/A/A1, or $/A/A1/A1AA, .. ; set RestrictNavigation = false, then end user can switch to $/B, $/C.
  Did I miss something? Thank you so much for your time.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
wayne.brill
in reply to: wesbird
Hi Wes,
There is not a property that will make the VaultBrowserControl only allow the user to select files in a folder and it's sub
folders. (I asked a colleague in Vault Engineering about this)
You could request an enhancement on the Vault Idea station to make RestrictNavigation allow more options:
http://forums.autodesk.com/t5/Vault-IdeaStation/idb-p/2
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
wesbird
in reply to: wayne.brill
Thank Wayne.
