Currently, I'm developing an application in Visual Basic .Net 2010 with Autocad 2013 and I want to have information on how to use commands (Vltlogin, Vltlogout, Vltopen, Vltcheckin, Vltimport, Vltcheckout, Vltundocheckout, Vltattach, Vltrefresh, vltoptions) of Vault 2013 in AutoCAD 2013, send the parameters required and avoid dialog boxes for each command.
for example:
I want to open a document using command "_vltopen" by sending the parameters required (path and filename) and avoid showing the dialog "Select File".
someone could help me, please
thank you very much
