There is a way (API) to get Vault Explorer to jump locations (Go To Folder) from a Vault Explorer plugin app ?
I get the right Folder ID, how can i do ? Thank you.
Solved by wayne.brill. Go to Solution.
I don’t believe there is a way to drive Vault Explorer’s GUI from a Vault extension.
You can only react to changes from it. The only time you can affect the selection in Vault Explorer from an extension is ICommandContext.GoToLocation property when a custom command is being executed, but I can’t see a way the you would be able to leverage that functionality to accomplish what you are trying to do.
You could log this request on the Vault Idea station:
http://forums.autodesk.com/t5/Vault-IdeaStation/idb-p/2
Wayne
