I'm using the VaultBrouserSample included with the SDK in Vault 2014 to find all files with a certain String contained in the File Name. Surprisingly I found that the API functions returns diferent results that the Vault Find froms (See attaced pictures).
The API's results contain all the characters included in the search condition striong, but not all of them in a row. Is this expected behaviour? Is there any configuration opction to change this?
This is the configuration on my search:
PropDefId = 10, // File Name,
PropTyp = PropertySearchType.SingleProperty,
SrchOper = 1, // Contains
SrchRule = SearchRuleType.Must,
SrchTxt = File_Name, // Text
Please advice if I'm missing some additional configuration.
Pablo
Yes, the Advanced Find Form uses FindFilesBySearchConditions in the back end.
Looking at your screenshots, it looks like DWF files are the main difference in the results. DWF files are hidden by default, so my guess is that the Advanced Find Form is filtering hidden files and our custom form is not. At the API level, File.Hidden is just meta data. It's up to the client to honor or ignore the setting.
Hi Doug,
Thanks very much for the quick answer.
You are correct it is only the DWF files that does not complain with the search criteria (File name contains TXT).
Pablo
Hi Doug, and everybody else:
After playing a bit more with the "FindFilesBySearchCondition", I'm convinced that it behaves the same as the Vault advance Find. But I’m not sure this is the intended behaviour. At least is not what I expected.
In the attached “TPN11.bmp” you will see how the search returns a lot of files that contains the characters “T”, “P”, “N” “1” and “1” in the right order, although not consecutive (Not only dwf files). That's not what I expected but I can work around this by filtering the search results.
More annoying is the difference between the searches “114165.bmp”, that returns a bunch of files with the string “114165” in the file name, and the search in “11416.bmp”, that does not find any file with the string “11416” in the file name… I’m very confused by this results.
Has anybody experience issues with this function before?
I’m I doing something wrong in my search settings?
Thanks for the help
Pablo
