Vault Customization
Vault Customization
Active Contributor
michael.collins2
Message 1 of 4 (198 Views)
Is a message on failed login possible?
198 Views, 3 Replies
09-12-2012 07:15 AM
Is it possible to get a message on a failed login, such as
- license limit has been reached
- Vault database not found
- username and password not found
Mike
PS I am using the WebServiceManager in Vault Professional 2013.
So for login errors, am I on the right path with something like:
try
    m_serviceManager =
    new WebServiceManager(newUserPasswordCredentials(
         server, vault, username, password, true));
catch (Exception ex)
  string errorCode;
  List<string> restrictionCodes;
     GetErrorAndRestrictionCodesString(ex, out errorCode, out restrictionCodes);
Employee
Redmond.D
Message 2 of 4 (184 Views)
Re: Is a message on failed login possible?
09-13-2012 05:03 AM in reply to: michael.collins2
If something goes wrong with the login, you will get an exception when creating the WebServiceManager object.  Errors from the Vault server will have an error code.
http://justonesandzeros.typepad.com/blog/2011/11/getting-the-restriction-codes.html
If you want a human readable message, you will have to convert the error code to a human readable string.  You can provide you own messages or copy them from the SDK documentation.
http://justonesandzeros.typepad.com/blog/2012/01/better-error-messages.html
Doug Redmond
Software Engineer
Active Contributor
michael.collins2
Message 3 of 4 (181 Views)
09-13-2012 07:19 AM in reply to: Redmond.D
try
    m_serviceManager =
  string errorCode;
Employee
Redmond.D
Message 4 of 4 (171 Views)
09-14-2012 05:26 AM in reply to: michael.collins2
Yes, that should work.  You can test it out pretty easliy.  Just log in with a bad password.
Doug Redmond
Software Engineer
