Hi
I'm close to finish my first Vault Addin. I like to add some image to my pulldown menu items just like Doug did for his Thunderdome project. It does not works. please check the attached screenshots.
Here is the code
CommandItem TaskReportItem = new CommandItem("ABCD.Command.TaskReport", "Task Report") { Image = Icons.Report, ToolbarPaintStyle = PaintStyle.TextAndGlyph, };
I also use the similar code to add image to some File/Change Order context menu items, those works fine.
Thanks for your help
Wes
Hi Wesley,
Trust everything goes well 🙂
Did you look into this blog post? http://justonesandzeros.typepad.com/blog/2010/03/command-icons.html . And did you check the format and size of the ico file? You can send us a sample project for more investigation if it still does not work for you.
