Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
How to read systemproperty Provider from File in vault professional
3 REPLIES 3
kbo
1167 Views, 3 Replies
We use dwg fore both Autocad and inventor 2D drawings. I run a program that checks the lifecycle state on files with extension ".dwg" and release these files if the state isnt "Released". The problem is that i want to filter out ".dwg" files where the system property Provider equals "Inventor DWG".
I know how to get the the master iDs of the files, but how do i read the "provider" property from these files to check if the file is a Autocad or Inventor dwg.
Please help with a little code example i vb.net
regards Kent Bøttger
3 REPLIES 3
Daniel.Dulzo
in reply to: kbo
Hello Kent,
You can read the Provider property just like reading other file properties in Vault. You can use the PropertyService.GetProperties() method, passing in the property id's of the property values you want and the file id's of the files you want to get the properties from. Here is a brief code sample:
 Using wsManager As New WebServiceManager(New UserPasswordCredentials("localhost", "Vault", "Administrator", ""))
     Dim file As File = wsManager.DocumentService.GetLatestFilePathsByNames(New String() {"Drawing1.dwg"}).First().FilePaths.First().File
     Dim providerPropDef As PropDef = wsManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE").First(Function(propDef) propDef.SysName.Equals("Provider"))
     Dim providerPropInst As PropInst = wsManager.PropertyService.GetProperties("FILE", New Long() {file.Id}, New Long() {providerPropDef.Id}).First()
     Dim providerString As String = TryCast(providerPropInst.Val, String)
End Using
The code above doesn't perform any error checking and uses some hard-coded values you'll probably want to change, but it should be enough to get you started. More information on the PropertyService and the methods it provides can be found in the SDK documenation, as well.
Regards
Daniel Dulzo
Software Engineer
Autodesk, Inc.
kbo
in reply to: Daniel.Dulzo
Thanks Daniel you code did the trick. I created 2 functions 1 to check for the provider and 1 to check if the file is currently checked out? The problem now is that error 1092 is thrown when a file is checked out? i try to read the
Checked Out By property on the file and if its not empty i know the file is checked out? but it throws an error, what am i missing here.
Regards Kent Boettger
 Public Function ReadPropertyProvider(servername As String, ByVal Myfile As String)
        'Login with Windows User login
        Dim winAuthSvc As WinAuthService = New WinAuthService()
        winAuthSvc.Url = "http://" + servername + "/AutodeskDM/Services/WinAuth/WinAuthService.asmx"
        winAuthSvc.UseDefaultCredentials = True
        winAuthSvc.SecurityHeaderValue = New WinAuthSvc.SecurityHeader()
        'winAuthSvc.SignIn("VaultDemo")
        Dim DocSrv As DocumentService = New DocumentService()
        DocSrv.SecurityHeaderValue = New Autodesk.Connectivity.WebServices.DocumentSvc.SecurityHeader()
        DocSrv.SecurityHeaderValue.UserId = winAuthSvc.SecurityHeaderValue.UserId
        DocSrv.SecurityHeaderValue.Ticket = winAuthSvc.SecurityHeaderValue.Ticket
        DocSrv.Url = "http://" + servername + "/AutodeskDM/Services/DocumentService.asmx"
        Dim DocSrvExt As DocumentServiceExtensions = New DocumentServiceExtensions()
        DocSrvExt.SecurityHeaderValue = New Autodesk.Connectivity.WebServices.DocumentExSvc.SecurityHeader()
        DocSrvExt.SecurityHeaderValue.UserId = winAuthSvc.SecurityHeaderValue.UserId
        DocSrvExt.SecurityHeaderValue.Ticket = winAuthSvc.SecurityHeaderValue.Ticket
        DocSrvExt.Url = "http://" + servername + "/AutodeskDM/Services/DocumentServiceExtensions.asmx"
        Dim PropSrv As PropertyService = New PropertyService()
        PropSrv.SecurityHeaderValue = New Autodesk.Connectivity.WebServices.PropertySvc.SecurityHeader()
        PropSrv.SecurityHeaderValue.UserId = winAuthSvc.SecurityHeaderValue.UserId
        PropSrv.SecurityHeaderValue.Ticket = winAuthSvc.SecurityHeaderValue.Ticket
        PropSrv.Url = "http://" + servername + "/AutodeskDM/Services/PropertyService.asmx"
        'Dim login As WinAuthCredentials = New WinAuthCredentials(serverName, "VaultDemo")
        Dim login As WinAuthCredentials = New WinAuthCredentials(servername, "VaultDemo")
        Using serviceManager As New WebServiceManager(login)
            Dim file As File = serviceManager.DocumentService.GetLatestFilePathsByNames(New String() {Myfile}).First().FilePaths.First().File
            'Dim file As File = serviceManager.DocumentService.GetLatestFilePathsByNames(New String() {"KBO1.dwg"}).First().FilePaths.First().File
            Dim providerPropDef As PropDef = serviceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE").First(Function(propDef) propDef.SysName.Equals("Provider"))
            Dim providerPropInst As PropInst = serviceManager.PropertyService.GetProperties("FILE", New Long() {file.Id}, New Long() {providerPropDef.Id}).First()
            'MsgBox(providerString)
            Return providerString
        End Using
    End Function
    Public Function ReadPropertyCheckedOutBy(servername As String, ByVal Myfile As String)
            Dim checkedoutbyPropDef As PropDef = serviceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE").First(Function(propDef) propDef.SysName.Equals("Checked Out By"))
            Dim checkedoutbyPropInst As PropInst = serviceManager.PropertyService.GetProperties("FILE", New Long() {file.Id}, New Long() {checkedoutbyPropDef.Id}).First()
            Dim checkedoutbyString As String = TryCast(checkedoutbyPropInst.Val, String)
            Return checkedoutbyString
        End Using
    End Function
kbo
in reply to: kbo
never mind i did the check this way, Again daniel thanks for your help.
 If file.CheckedOut = True Then
                                MsgBox(Myfile & " Is Checked Out")
                                GoTo DONT_RELEASE
                            End If
