Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
How to obtain the numberingSchemeId
2 REPLIES 2
545 Views, 2 Replies
I am trying to add new Items to Vault 2013 Professional through the API.
It seems like I need to use the itemSvc.AddItemNumbers() method to assign the Item Number that I want to my new Item.
That method needs a parameter called numberingSchemeId.  Our Item numbering schema is called "Mapped" and is the default item numbering schema.
How can I obtain the ID for this numbering scheme?
2 REPLIES 2
Redmond.D
Call GetNumberingSchemesByType and loop through the results until you find the NumSchm object that you want.  From your message, it sounds like you are looking for the scheme where Name == "Mapped" or the scheme where IsDflt == true.
Doug Redmond
Software Engineer
Autodesk, Inc.
in reply to: Redmond.D
Thanks Doug, that seems to work:
private long GetItemNumberingSchemeID(string schemaName)
   long sId = 0;
   NumSchm[] allSchemes = itemSvc.GetNumberingSchemesByType(NumSchmType.All);
   foreach (var schema in allSchemes)
      if(schema.Name == schemaName)
                    sId = schema.SchmID;
                    break;
   return sId;
