Hi all,
I would like use the AutoLogin checkbox.
If Autologin is checked the Login form should not be displayed and the login should be automatic.
It is possible?
Thank's
Michele
Solved by Redmond.D. Go to Solution.
Yes. To use the auto login feature, you need to provide LoginSettings. The AutoLoginMode property determines how you want auto login to work. You should also provide a PersistenceKey, so that the saved settings are unique to your app.
Thank's Redmond.
But it is possible find the value of current AutoLoginMode property of Vault Client?
Thank's...
Michele
The intent is for each app to have their own settings. There is no API suppoprt for reading another applications Vault login settings.
Sorry Doug,
but I still have a doubt...
It is not possible to know if auto login to next session is enabled on Vault by code? There is this information?
Thnak's
Michele
