Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
How to get file checked in record?
3 REPLIES 3
hsxlong
226 Views, 3 Replies
     I want to get all record of file when it checked in
   Record include userId who checked file in and changeOrderId that file associated with
   thank you!
3 REPLIES 3
smithmat
in reply to: hsxlong
What have you tried?  Where are you stuck?
hsxlong
in reply to: smithmat
I just get all file versions and I find that Vault do not create a new version when checked file in without change
The main problem: I can't find user who checked file in,and related changeOrder , the property in file is only userId who checked file out , and just valid when file is being checked out.
I want get user who checked file out and changeOrderId associated with
smithmat
You are correct that when you check in a file that hasn't changed, Vault just does an "undo checkout" instead.  There is no record of this whatsoever.
So for a file that was unchanged and thus an undo checkout occurred, you will not be able to find out who attempted the check-in (which actually resulted in an undo checkout).
