I want to get all record of file when it checked in
Record include userId who checked file in and changeOrderId that file associated with
thank you!
You are correct that when you check in a file that hasn't changed, Vault just does an "undo checkout" instead. There is no record of this whatsoever.
So for a file that was unchanged and thus an undo checkout occurred, you will not be able to find out who attempted the check-in (which actually resulted in an undo checkout).
