Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
how to check if a downloaded file the latest?
1 REPLY 1
wesbird
391 Views, 1 Reply
  If I found a same name file with same path at working folder, does that means the file been downloaded? How to I check if it's the latest version of file? I just try save some traffic to download the file again.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Redmond.D
in reply to: wesbird
If you have the FileIteration object, ther is a special property you can read to get the Status information, which includes things like if the local file is up-to-date.  http://justonesandzeros.typepad.com/blog/2013/08/getting-the-status-icon.html
Doug Redmond
Software Engineer
Autodesk, Inc.
