I am in a project which deals with Vault 2013 and using C# as development language. The project is nearing completion but stuck up in a small issue.
I am trying to fetch the Name of Vault to which user has logged in using WebServiceManager. Few functions from RestrictOperation code which is present in SDK.
When lifecycle state change is triggered i am trying to get VaultName, is there a way to get this.
Cheers,
Amit
Solved by amitnkukanur. Go to Solution.
string GetVaultName( WebServiceManager wsmgr ) { return wsmgr.WebServiceCredentials.VaultName; }
-Dave
Hello MinkD,
Thanks for reply, I used the code given by you.
In this above piece of code when i type wsmgr and Press .(Dot) i am not able to find WebServiceCredentials.VaultName in Intellisense.
Rgds
Amit
That must have been added after 2013. If that is the case I'm not sure how to get it in Vault 2013 - hopfully, someone else can.
-Dave
Hi MinkD,
Thanks for reply, i found it after doing a bit of R'n'D.
Cheers,
Amit
