Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Get VaultName from WebServicemanager
4 REPLIES 4
amitnkukanur
427 Views, 4 Replies
I am in a project which deals with Vault 2013 and using C# as development language. The project is nearing completion but stuck up in a small issue.
I am trying to fetch the Name of Vault to which user has logged in using WebServiceManager. Few functions from RestrictOperation code which is present in SDK.
When lifecycle state change is triggered i am trying to get VaultName, is there a way to get this.
Cheers,
Amit
Senior Software Engineer
4 REPLIES 4
minkd
in reply to: amitnkukanur
string GetVaultName( WebServiceManager wsmgr ) { return wsmgr.WebServiceCredentials.VaultName; }
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
in reply to: minkd
Hello MinkD,
Thanks for reply, I used  the code given by you.
In this above piece of code when i type wsmgr and Press .(Dot) i am not able to find WebServiceCredentials.VaultName in Intellisense.
Rgds
Amit
minkd
That must have been added after 2013.  If that is the case I'm not sure how to get it in Vault 2013 - hopfully, someone else can.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
amitnkukanur
in reply to: minkd
Hi MinkD,
Thanks for reply, i found it after doing a bit of R'n'D.
Cheers,
Amit
