Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Get user associated group info
6 REPLIES 6
santoshr0114
925 Views, 6 Replies
Dear All,
How to get all the groupinfo's associated to a particular user.
Ex:
User : Santosh is associated to Design & Production gruops.
Using API i need to get the groups the user "Santosh" is associated with.
Any example would be helpful.
Thank You in advance
Regards
Santosh
Tags (3)
6 REPLIES 6
minkd
in reply to: santoshr0114
There is no way for a regular user to get GroupInfo objects - only Administrators can do that.
However, if you are trying to determine if a user is in a specific group, you can do that with the GetGroupByName call in the AdminService. If the user is in the group, it will return a Group object (not a GroupInfo object); otherwise, it will throw a PermissionDenied exception.
-Dave
Dave Mink
Fusion Lifecycle
santoshr0114
in reply to: minkd
Thank You for your reply.
i am aware that i have to be logged in as administrator.
I want to know what groups a specific user is associated with.
Currently i am running a loop using individual userid in groups and gettgin the output perfectly.
Is there any other method to accompish the same task..?
Regards
Santosh
Redmond.D
Yes, cycling through all the groups and users is really the only way to do it.  Keep in mind that groups can have groups, so a user may be "in" a group even if there is no direct link to that group.  Effective Permissions has some code related to this issue, so you may want to have a look at the code.
Doug Redmond
Software Engineer
santoshr0114
in reply to: Redmond.D
Thank you for your reply Doug.
Will try the method
Regards
Santosh
Alainmorin
Did you have any luck Santosh?
Maarten65
Can you publish the code which scanned all users and their groups?
Maarten Weers
Technical Specialist CAD - EMEA
Parker Hannifin
Oldenzaal - The Netherlands
Inventor Pro 2019 - Vault Professional 2019 - Windows 10 64 bit -
