Hello All,
I am so lost. I am trying to find out which files in Vault get updated or changed (such as renamed). Is there a property or API I could look at? I'm assuming it's a type of archive bit like Windows does, but I have no idea. If anyone has a link to methods or anything it would be very helpful.
Thank you.
Solved by Redmond.D. Go to Solution.
Files have a property called Date Modified. You can search on this property, for example, to find out which files were modified in the last 24 hours.
DocumentService.FindFilesBySearchConditions is the funciton you want. Here is an article that should tell you most of what you need to know: http://justonesandzeros.typepad.com/blog/2012/09/finding-by-search-conditions.html
