I've got an issue when a file is larger then about 45MB and I want to download it trough the filemanager.AcquireFiles(MySettings)
Smaller files will download correctly.
Dim results As Autodesk.DataManagement.Client.Framework.Vault.Results.AcquireFilesResults = m_conn.FileManager.AcquireFiles(vlt_Settings)
I've tried to implement the downloadfilepart (without success).
In the documentation I found it should automaticaly handle large files.
We are on ADMS 2015 SP1 and Vault Client 2014 SP1
Regards
Peter
Solved by smithmat. Go to Solution.
Where is this code running from? Your own exe or as a Vault extension?
If it is your own exe, I wonder if it might be due to you missing the necessary mtom settings in your application's configuration file. See http://justonesandzeros.typepad.com/blog/2010/03/file-transfer-as-binary-data.html
What error are you getting?
- Matt
