Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Filemanager.Acquirefiles issue
2 REPLIES 2
399 Views, 2 Replies
I've got an issue when a file is larger then about 45MB and I want to download it trough the filemanager.AcquireFiles(MySettings)
Smaller files will download correctly.
Dim results As Autodesk.DataManagement.Client.Framework.Vault.Results.AcquireFilesResults = m_conn.FileManager.AcquireFiles(vlt_Settings)
I've tried to implement the downloadfilepart (without success).
In the documentation I found it should automaticaly handle large files.
We are on ADMS 2015 SP1 and Vault Client 2014 SP1
Regards
Peter
2 REPLIES 2
smithmat
Where is this code running from? Your own exe or as a Vault extension?
If it is your own exe, I wonder if it might be due to you missing the necessary mtom settings in your application's configuration file.  See http://justonesandzeros.typepad.com/blog/2010/03/file-transfer-as-binary-data.html
What error are you getting?
- Matt
in reply to: smithmat
Yes it's my own exe.
Completing the config file was the solution.
Peter
