Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
File.Hidden=True not hiding file
3 REPLIES 3
Mzwijacz
453 Views, 3 Replies
I'm trying to mark a file for later processing and hide the file from the user. I found the File object has a Hidden property. When I set the property to true, the file remains visable. If I log in as guest or some other non-Administrator account, the file is visable.
void Test_Execute(Object sender, CommandItemEventArgs e) { //get connection object VDF.Vault.Currency.Connections.Connection conn = e.Context.Application.Connection; IEnumerable<ISelection> Selection = e.Context.ViewSelectionSet; foreach (ISelection Selent in Selection) { if (Selent.TypeId == SelectionTypeId.File) { File MasterFile = conn.WebServiceManager.DocumentService.GetLatestFileByMasterId(Selent.Id); // check if file is locked or checked out if (!MasterFile.Locked || !MasterFile.CheckedOut) { //Hide the master file MasterFile.Hidden = true; }//end if not checked out or locked }//end if is file }//end for each file }//end void Test_Execute
Not sure why the file remains visable
MFZ
3 REPLIES 3
smithmat
in reply to: Mzwijacz
There is a Vault Explorer client setting which determines whether hidden files show up for the user or not: Tools->Options->Show hidden files.:
Hidden files are not a security feature--any user can see them if they want to.
- Matt
minkd
in reply to: smithmat
In addition to Matt's comment, your code is not changing the file to hidden.  You have to checkin the file with hidden=false (hidden is a parameter of the checkin method).
-Dave
Dave Mink
Fusion Lifecycle
Mzwijacz
in reply to: minkd
How do I mark this thread as accepted ? I don't see a link or a menu anywhere.
